Need licence / product key for FileMaker Pro 11
Hi guys,
I need to reopen an old FileMaker Pro 11 project, but I lost the product key that was on the box, which I threw away.
Can someone give/sell me one they no longer use (I can pay €10)?
Best regards, Marcos
Just get the current version from 2025 and open the database. Then FileMaker Pro converts it.
On 12/19/2025 at 6:40 PM, Ocean West said:
Thanks you, but sadly I already used the trial version on my PC by the past, so I can't use it anymore
Thanks for the idea.
Yes I may try the conversion from *.fp7 to *.fp12 using FMP >= 12, but I'm afraid that it can break something.
If I can't get a product key for FMP11, I'll do it. But I'd prefer to use FMP11 with a product key.
Furthermore, I do not have a product key for a newer version, and I do not know if the 30 days of a trial version will be long enough.
Hi @Ocean West ,
You gave me links to download the trial version of FMP11.
Do you also know a link to download the Plug-In SDK for FMP11 ?
I looked on the official page https://www.claris.com/resources/downloads/ but there is only fm_plugin_sdk_22.0.1.68.zip which is to recent for me.
