November 7, 200223 yr I have a database that users use through there web browsers, the problem im having is when trying to add a new record it will only let me add data into certain ones. Any ideas? Thanks for any advide. Chris.
June 7, 200421 yr i had a problem a bit like that, and it turned out the fields were behind other graphic objects (ie boxes) on the layout. once i selected the fields and selected 'send to front' i no longer had the problem j
