March 27, 200620 yr Got a strange problem with Filemaker advance 8. When trying to view a database connecting to IWP through http://127.0.0.1:80 I get a "The maximum number of users allowed to connect to this server has been exceeded". In Filemaker 7 it works without any problem. And the only user accessing is me (1 user). Any suggestion for what can be done?
March 31, 200620 yr Author I have restarted the database and it still won´t let me access through local machine. ;)
March 31, 200620 yr what operating system are you using? i may be wrong but if its a windows system maybe to do with firewall settings. when you connect to the database via FMP8 and try accessing a record i.e. editing a record do you get a message stating another user is modyfying the record? also the system you are accessing via IWP make sure you close the browser even try a a restart to be sure!!!
April 3, 200620 yr Author It may be the Windows firewall.. I didn´t even think of that. I am not so used to work in Windows enviroment... Will turn it off and try again. ;)
