Password System Help
I'm trying to set up a web based password system for a client using
FileMaker Pro. I already have the passwords and ID generated. What I need
to
know now is how I get it to look at the database, spawn a matching ID and
password set to the screen and then remove it from the database. The
passwords and ID are already hardcoded into the users area in the server
settings under WebStar.
I've got the database to hand off variables to the secure e-commerce
system
of the client (Hosted on another system), once the credit card is validated
then it comes back the original server and what I'd like to have happen is
that the user then gets the unique ID and password set after which that
particular pair is then removed from the database, but it places the user's
name and various information to what group the user belongs to into a
separate database.
Any help or ideas would be greatly appreciated.
Tony Broyld
This is more of a WebStar question than a FMP question. The password database would be just that, a database that you can edit with CDML tags.
Getting info into and out of WebStar is another different matter. AppleScript?
