March 14, 200125 yr Newbies I'm new to the world of Filemaker and I've come across an annoying problem. I hope you guys can help. We host a DB using Filemaker server 5 and the Filemaker Pro 5 web companion on a NT server. Every morning when I come to work Filemaker Pro is not hosting the file, the program will be up but nothing is up on the screen and I can
March 14, 200125 yr You're running the FMP server and FMP Unlimited with the Web Companion on separate machines, right?
March 14, 200125 yr Author Newbies They are on the same server but I did try it separated and it had the same out come. quote: Originally posted by dspires: You're running the FMP server and FMP Unlimited with the Web Companion on separate machines, right?
April 23, 200124 yr Newbies I was having the same problem and found that in the FMServer setup I had a timeout setting for disconnecting users after remaining idle for a period of time...
