newbie in SOAP need help for his first request
Hello,
I don't know if I'm in the right forum but I try.
I'm experienced in FMP for 10 years but not in PHP, and SOAP requests.
I need to interact with a webservice for sending orders (products ID and quantity).
I've got the WSDL from  the service ,read a lot on SOAP but I'm not able to write my SOAP request to test it.
Can someone help me and put me on the way ?
In the WSDL (attached file) I need just to use  the vetapswuploadorder, not the product search or the command search.
As you see there is a test URL :
And I've got a password if someone want to look at I'll give it to you.
Thanks a lot.
Kind regards.
Antoine Adam
091026-Vetpoint_AnbindungTapSoftwareSpezifikation_V092-f.pdf
Hi Antoine Adam,
I don't think that you get some deep response from this Forum because here mostly FM database and database communication/ solutions discussion are going on. So I can suggest you to go to the below link and post your query, where you will get solution to your problem.
http://stackoverflow.com/
Sorry I'm late but I thought I was following this discussion.
Thanks for the links I'm gonna see them.
I had contact with 360works.
Kind regards.
Antoine
360 has their own Topic Area. I can move this to one of their subtopics if you want, just let me know which one.
  • 5 months later...
Sorry I didn't see your answer !
and I don't know exactly what to reply. I've post a reply to a topic tonight about sending xml data and ask for help.
Maybe you can see it and see if it's usefull for you to help me ???
kind regards.
Antoine
