FileMaker 12 Connection Problem
I have a server on one of the ISP. For more than one years it is running.
But today I can not connect to databases published. I have checked the port number 5003, it is open. Windows firewall is off.
FileMaker sever is running, I can connect server by the filemaker runs on the server machine. FileMaker running on the server machine can not connect any other server. CWP page is running over http.
I am missing something, what could I do to solve this problem?
Regards,
Osman
Since it was running before and now not, something setting was changed.  Find out what work / updates the provider has done.
Triple-check that port 5003 is open.
Thank you Wim
I have checked port www.canyouseeme.org and network utility. Both of seems the port open.
But problem has gone. You are right, problem was related to our provider's network settings.
Have a nice day.
