FMP 13 - Web Direct - Improperly displaying list layout with sub-summary parts
(public link for this doc)
https://docs.google.com/document/d/1zIbF13RSlaW230-NlYicGZxHB3FsYvQt-U0fFL9uwEU/edit?usp=sharing&pli=1
I am having a problem with Filemaker Pro 13’s Web Direct handling of a simple list layout with sub-summaries.
The sub summaries, when added, seem to be cutting off the first (or last*) row of detail in the body.
* If the sub-summary is above the body it cuts off the first row.
* If the sub-summary is trailing the body, it cuts off the last row of detail.
(this example includes 5 records which should be grouped into three groups (by ID number).
Hopefully these diagrams help:
I also attached a PDF version of these diagrams.
FMP13-WebDirect-Improperlydisplayinglistlayoutwithsub-summaryparts.pdf
  • 3 years later...
Anybody have a solution to this?   It looks to still be an issue in FM16 WebDirect too.
TIA
  • 2 years later...
Wow, I'm having the SAME issue with FileMaker 18 WebDirect. After some experimentation I have found a possible workaround.
You can replace a Leading Grand Summary with a Header if you use a Title Header or Top Navigation as well, and you can replace a Trailing Grand Summary with a Footer if you use a Title Footer or Bottom Navigation as well. Basically if you use a Title Header/Footer and/or Top/Bottom Navigation, then the standard Header/Footer parts don't get repeated every page and can take summary fields. This has eliminated the above problem for me. It's not a perfect solution and it may have other consequences based on your own layouts, so YMMV.
ADDENDUM: I haven't tried this with subsummary parts, only leading and trailing grand summaries. This probably won't work with subsummary parts if you need to sort them on a field.
