Better way to CrossTab than FM Advanced training book?
I have a need for a lot of cross tab calculations and have referred to the FM 13 Advanced Training Series, lesson 38 which covers this.  I've used it for a while now but it's brutal in that you need to create two calculations for each individual 'cell' you wish to display:
One calculation tells Filemaker what should be summarised, usually via a CASE statement.
The other is the Summary field itself which appears on the layout.
I tend to require 10, sometimes more columns which are based on date fields from an overall record list of 70000 so far.
Is there not a better way of doing the cross tab calcs, something like (psuedocode) as I'm wary of fattening up the fields on the DB:
  • Calc1::DoSummary (Case (DatePeriod = 1 and SortField = "Tourist" ; Amount))
Rather than two calculations:
  • Calc1 ::Case (DatePeriod = 1 and SortField = "Tourist" ; Amount)
  • sCalc2L::Summary Calc1
Thanks all
