Buttons problem with Web companion
I have these buttons setup to navigate through records. nothing fancy, not scripts.. built in things.
When I use a simple text filed called "goto next", make it a button to do just that, it works fine in the browser. However, if I do the same thing to my graphic I made, the graphic appears in the browser, but it doesnt work as a button. I cant click on it at all.
Any ideas why this might be so?
thanks!
My guess as to "why this might be so" is that you are using IWP, which must generate the HTML on the fly - and you have not told the db file or Web Companion or whatever it is that generates the HTML how to recognize the image as a button.
Images can be made into buttons quite easily with CWP.
