Window resize problem
The size of filemaker window vary from machine to machine. I tried 'window resize' option but it is no web compatible. Also Refresh Window option is giving strange troubles like records are not displayed. Please suggest a method to keep size of window as 'fit to screen' and same on all machines.
Tushar
You cold draw a box in the back layer that is the same size on all layouts.
Then use Adjust Windows (resize to fit).
Don't understand the refresh problem.
Apologies - this would only work in FMP, not IWP
Thanks for the suggestion, it is working. Now I am able to resize the window to 'fit to screen' or 'maximum'. But the layout objects do not resize accordingly, i.e. window expands but layout objects remain at same place thus leaving some portion of window empty. Please suggest a method to keep size of window as 'fit to screen' and same on all machines along with layout objects.
Tushar
