calculated container url problem
I am publishing a production tracking database using IWP and want thumbnail images to appear on the detail page. I have a calculation with result container to access the images stored on another webserver. The problem is that the url required to access the images is case-sensitive (ie /Volumes/Raid/ is not the same as /volumes/raid/) but the url that Filemaker uses is all lowercase. I have tried Upper() but it makes no difference. Any ideas?
  • 1 month later...
This can probably not be solved at the Filemaker level...
Modify the URL at the server level. Ideas:
-make a new mountpoint/share with a suitable name
-use a URL rewriting technique (like mod_rewrite in Apache) to fixup the 'broken' URLs coming from IWP
YMMV
/HotSupport
