March 8, 201115 yr Hi, Im trying to set up IWP on my Windows 2008 server, using FMSA 11. I can get this to work when I host the file from Filemaker Pro, however I'm confused about what I need to do when hosting from the FMSA console. I have the server configured correctly I believe. Im using the IIS web publishing engine and have the IWP turned on in the Admin console. The file has the check marks next to it in the console indicating that the access is configured correctly in the file itself. I also cannot get the FM_Sample file to display either. When I run the test I receive the following error on the test page... "HTTP Error 404.0 - Not Found". Any help would be greatly appreciated. Thank you, Ron
