How to setup Shortcut keys to Script? - Help Please!
Hi All,
I have a layout where there is a "New" button to add a new record. When the new button is clicked, it performs various scripts (e.g. new record, set field, etc.) However, when the user uses the shortcut key CTRL+N to create a new record on this layout, it does not go through the script steps. Is there a way or is it even possible to tie the shortcut key to the "New" button? I have other layouts that has "New" button as well but performs a different "SetField" script, i would like CTRL+N to be dynamic depending on layout.
Any help would be greatly appreciated!
Thank you.
Your question could fit into a lot of the Topic Areas, including this one. However, it is not a Custom Function you need.
You can have up to 10 script display in the Script menu if you check the box in Manage Scripts.
Why not attach a copy of your file?
