IWP portal display problems
I have a portal set to display 6 rows, formatted with a vertical scroll bar. This portal displays fine in IWP, provided that the portal contains 6 or less line items.
However, if there are actually 7 or more such items then the portal display goes crazy in IWP.
Has anyone else seen this, and if so, is there a work around?
How about attaching a screenshot?
The attachment shows two screenshots: the first is how it looks in IWP, the second is how it should look.
IWP_screenshots.zip
