May 26, 200817 yr I opened my computer today and went into filemaker and I got a dialog that says I need to change ports for web publishing because there is a conflict. I haven't used web publishing. I have it set by default to 80; I change the number and it closes. Says there is a conflict. I can't open filemaker at all. What should be done. I am on version 9 on a mac Thanks
May 26, 200817 yr Possibly you have a corrupted preferences file. Delete the following file: ~/Library/Preferences/FileMaker Preferences/FileMaker Pro 9.0 Prefs It will regenerate automatically next time FMP is started. Edited May 26, 200817 yr by Guest
