Script Trigger will not work with IWP
I have a script trigger on fields to pop "updated" into a field that I can keep a check on. If a user updates certain fields, the updated record are shown in a list. All works fine but on with IWP.
Any ideas?
Did you read the FM help guide? See below
In Instant Web Publishing and Custom Web Publishing, script triggers can only be activated by a script and not by direct user interaction. For example, if a user tabs into a field that has an OnObjectEnter script trigger, the trigger will not activate. If a script step causes focus to move into that field, the script trigger will activate.
Ok, thanks for your help.
