Issues Going To Layout After Commit Records
This one has been troubling me for some time now, probably something simple...
I have a layout with a portal that is access via Instant Web Publishing on FileMaker 12.
It has three butons;
1. Save & Exit - Which commits records and exits application.
2. Save & New - Which commits records and creates new record
3. OT - Which commits records and goes to another layout
Buttons 1 and 2 work, but not button 3.
On pressing button 3 it just commits records and remains on the same layout.
No validation errors appear. The user is on a full access account. The destination layout is a different layout to the current one.
Screen shots attached, any ideas?
post-103418-0-25274200-1371206602_thumb.
post-103418-0-65054500-1371206616_thumb.
post-103418-0-85147600-1371206664_thumb.
If you were using FM12 then you might have created the layout using one of the new themes - these are not supported in IWP. IWP only supports classic layouts.
Are you on FM12 and this is a themed layout??
Is the ShiftData layout based on another FM file that hasn't got the IWP privilege enabled?
Thanks IdealData,
It was indeed an issue with non-supported themes!
