Novice needs help triggering script from checkbox set
I've not used FM Pro in some time and need help.  Just upgraded to FM12.  I have a check box list that user chooses to select which vendors will receive request for bid on new jobs entered.  What I want is a way to grab names from chosen check boxes and find corresponding email from a separate vendor list and then send a separate email to each vendor (I know how to set up email).  Unclear how I can accomplish this with check box.  In the past I've used buttons for each vendor (yes, long list and lots of work to set up) that triggers scripts.  However, the check box list would make it much easier.  Appreciate any help that can be provided, and remember I'm a novice so please break it down....  Thanks.
