March 15, 201412 yr Hi everybody, I am doing a POS system and I have 2 databases. The first one has the barcodes and descriptions of the products and the second one has the ordered products. I have a layout from which I would like to read the barcodes of the products and then add their information within the other database. To do it, I have a field through which I want to introduce the barcode. This barcode can be introduced handly or with a barcode reader. I have some problems to create the script to read the barcode. Handly: I write the barcode numbers, strike the enter key and a script "1" is started (when strike this key) to capture the barcode. Barcode reader: I click on the field and read the barcode, after that a script "2" is started to capture the barcode. To separate both scripts (1 and 2), in this field I have activated the OnObject Keystroke event and I run this script: Set Error Capture [On] Allow User Abort [Off] IF Code (Get ( TriggerKeystroke ) = 13) Perform Script [“Add barcode”] Else Exit Script End If Using this script I can read a barcode and the subsequent script runs perfectly but it is impossible to write handly any number within the field. How could I keep both reading options? Thank you very much, Wardiam
March 16, 201412 yr I don't quite get it. Why not click on the field to enter the number manually, but create a separate "scan" button to scan the barcode into the field? That would seem more intuitive to me.
March 16, 201412 yr Author Hi Matthew, It is a possibility, I would like to have a single field but if I don't get other solution to my problem, I will try your option. Thank you very much, Wardiam
March 16, 201412 yr IF Code (Get ( TriggerKeystroke ) = 13) This line needs to read: If [ Code ( Get ( TriggerKeystroke ) ) = 13 ] The way you have it, the test will always return true. Note that the Else part of the script is unnecessary. -- Note also that if the user enters a return while entering data manually, the same script will run. I didn't quite understand the 2 scripts thing.
March 16, 201412 yr Author It's true Comment, thanks. I have modified the script following your recommendations and now it works but I had to change the activation event to "OnObjectSave". As you told me I wanted that both actions (handly or barcode reader) run the same script, perfect!!! Now I have other problem, to activate the script I click on the enter key and when the script has finished the cursor goes to the next field. I want to return to the same field, clear it and introduce other barcode. I have tried to use the "Go to field" or "Go to object" commands at the end of the script but the field is only cleared and anyway the cursor goes to the next field. Do you have any suggestions? Thanks again, Wardiam
March 17, 201412 yr Hi Wardiam, OnObjectSave fires after the event (changes have been validated and saved). If the script returns true, the original event proceeds normally which is moving to the next field. To stop the field exit, use Exit Script[0]. But you also need a way out if you wish to stop the scanning. I have no barcode scanner here to test it so please, as always, back up first. Set Error Capture [ On ] Allow User Abort [ On ] If [ not IsEmpty ( table::field ) ] Perform Script [ “Add Barcode” ] Clear [ ] [ Select ] Exit Script [ Result: 0 ] End If
March 17, 201412 yr Author Thank you very much LaRetta, I have tested your script and it works. This is exactly that I wanted it. Thanks again, Wardiam
