March 8, 200521 yr I have all my pages in the web folder. and when I run the search page, it says database is not open, but I have it open? here is my html code: <form method="post" action="FMPro"> <input type="hidden" name="-db" value="portal.fp5"> <input type="hidden" name="-lay" value="Layout #1"> <input type="hidden" name="-format" value="edit.html"> <input type="hidden" name="-recid" value="[FMP-currentrecid]"> [FMP-Portal: relationship] <tr> <td>[FMP-Field: Title]</td> <td>[FMP-Field: Author]</td> <td>[FMP-Field: Genre]</td> <td><a href="[FMP-linkrecid: layout=Browse Books Layout, Format=details.html]">Details</a></td> </tr> [/FMP-Portal] </form> that is my result page and here is my search button: <form method="post" action="FMPro"> <input type="hidden" name="-db" value="portal.fp5"> <input type="hidden" name="-lay" value="Layout #1"> <input type="hidden" name="-format" value="results3.html"> <center> <input name="-find" type="submit" value="Show All Books"> <input type="text" name="relationship" value="1"> </center> <hr> </form> But it keeps telling me portal.fp5 isn't open, which is the name of one of my DB's
March 8, 200521 yr Author I have all my pages in the web folder. and when I run the search page, it says database is not open, but I have it open? here is my html code: <form method="post" action="FMPro"> <input type="hidden" name="-db" value="portal.fp5"> <input type="hidden" name="-lay" value="Layout #1"> <input type="hidden" name="-format" value="edit.html"> <input type="hidden" name="-recid" value="[FMP-currentrecid]"> [FMP-Portal: relationship] <tr> <td>[FMP-Field: Title]</td> <td>[FMP-Field: Author]</td> <td>[FMP-Field: Genre]</td> <td><a href="[FMP-linkrecid: layout=Browse Books Layout, Format=details.html]">Details</a></td> </tr> [/FMP-Portal] </form> that is my result page and here is my search button: <form method="post" action="FMPro"> <input type="hidden" name="-db" value="portal.fp5"> <input type="hidden" name="-lay" value="Layout #1"> <input type="hidden" name="-format" value="results3.html"> <center> <input name="-find" type="submit" value="Show All Books"> <input type="text" name="relationship" value="1"> </center> <hr> </form> But it keeps telling me portal.fp5 isn't open, which is the name of one of my DB's
March 8, 200521 yr Hi Zowsky - To start with your fields in the portal must be referencing the relationship (eg - >[FMP-Field:relationship::Title]. However, this looks like you are trying to return a list of books that the user then clicks on to see detail for a particular book. For this, you do not need a form on the result page, nor a portal. Try using a record command to show the found records Wrap an [FMP-Record] around your table row [FMP-Record] <tr> <td>[FMP-Field: Title]</td> <td>[FMP-Field: Author]</td> <td>[FMP-Field: Genre]</td> <td><a href="FMPro?-db=portal.fp5&-lay=Layout#1&-format=details.html&-RecID=[FMP-CurrentRecID]&-Find">Details</a><td> </tr> [/FMP-Record]
